E320 SIDE MIRROR
Old Mar 3, 2005 | 01:16 AM
rlteotico's Avatar
Default E320 SIDE MIRROR
I have a 1999 E320 and i want to know where to get a replacement driver side side mirror. I looked on ebay and they sell the mirror set only,but why is the left mirror reddish and the right side is regular. Right now my driver side mirror is also reddish very hard to see. I also want to know how to remove it.
Any Suggestions?
Also, I change my lights back to stock and the inside tells me lamp defective. How do i reset that?
Old Mar 3, 2005 | 05:49 AM
joedao2005's Avatar
Default RE: E320 SIDE MIRROR
Hi My Friend
Actually, after changing your light bulb, if it is no longer see defective one, the screen will say " No Malfunction". If it continue says "lamp defective". It meaans that there is still another defective one. You should turn on your light and walk around your car to see any missing light or hit the rear brake to see whether the brake lamp has defect. If no more defective bulb, the screen will automatically show you "no Malfunction" when you cruise around the arrow buttons at your left sterring wheel.
Regards,
Joseph
Old May 5, 2009 | 07:46 AM
WineGrl's Avatar
I have spent a lot of money on trying to get the LAMP DEFECTIVE message off but to no avail. ALL of the bulbs were replaced whether working or not to make sure they were all Mercedes bulbs, one headlight was re-wired even though it was working because wiring looked a bit frayed and cracking, all wires were checked throughout the car and nothing helps. Every light is working in and out, but that annoying message won't go away. My driver's side mirror did the same thing as yours (why?) and I'm replacing it. Anyone know what to do to get that LAMP DEFECTIVE message off?
e320.1995
Mar 15, 2009 05:51 PM
SLK320Chic
Oct 18, 2007 03:45 PM
Scuddog
Jul 9, 2007 06:26 PM
nineknot
Jun 20, 2007 06:26 PM
pmjbenz
Mar 29, 2005 10:53 PM
