2003 C230 cpe will not start
Old Nov 9, 2009 | 06:08 AM
GopherR5's Avatar
Default 2003 C230 cpe will not start
Three days ago, while pulling my 2003 C230 Komp. Coupe into the garage the check engine light came on. There is a about a 3-4 inch rise between the driveway and the garage. The car struggle a little to get over the hump (the engine bogged down), then then the check engine light came on. At the time I assumed that the light would be on temporarily.
This morning, I started the car and the CE light was still on, and the car seems to be idling a little rough. I started to back it out of the garage, and it stalled. Now it will not start. Any ideas?
Old Nov 9, 2009 | 11:20 AM
gr8pursuit's Avatar
Did you get your vent hose replaced? If not, there is a recall on it. Happened to me a 2 yrs ago, rough idle, then stalls. Campaign#2008020002.
Could be a lot of other things too. You need to check the diagnostic codes.
oexspx
Feb 15, 2010 06:42 AM
vinc68
Jul 7, 2008 03:36 PM
hk91308
Apr 5, 2008 01:21 AM
Trygve
Jul 7, 2007 02:13 PM
hk91308
Oct 9, 2006 03:07 AM
