Blown fuse in 1985 300TD
Old Nov 5, 2009 | 01:34 PM
momwagon's Avatar
Default Blown fuse in 1985 300TD
Does anyone know what would blow the #2 fuse (clock, trunk light, diagnostic, roof light front a. rear, hazard warn. system, illumin. vanity mitrror, warn. monitor term. 5, autom. antenna, switch-over valve seat back arrester, (elektron radio) in my 1985 300TD? It was blown when we bought it, and blew immediately when we replaced it.
Old Nov 15, 2009 | 05:15 AM
bknipfer's Avatar
My 1985 Mercedes 300SD Turbo Diesel had the same fuse blow when I went to remove the trunk light (as part of removing the trunk lid) when I put the light back I accidently shorted out two wired together. In moving the wires a wire was moved and hinge severed the wire clieanly. I suspect if you get inthe trunk and look on the driver side back by the hinge you will find one wire cut. The fuses blow flow quite easily so get a bunch at Autozone when you work on this. I used an electrician to find and do my repair as they know this space much better than auto mechanics. All is well now.
valleyd01
Jul 15, 2010 09:06 PM
MrBoogaty
Sep 4, 2009 10:45 AM
garibaef
Feb 17, 2007 08:39 AM
k20a2typer
Jan 1, 2007 05:21 AM
ddill
Nov 3, 2006 06:11 PM
