Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Mercedes E Class
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
Old 11-01-2009, 07:36 AM
raybenz raybenz is offline
Angry Front axle or boot
I got 2001 E320 4matic and just had the state safety inspection yesterday. It did not pass inspection due to the front left cv boot. Since I need to remove the axle to get to the boot. My question to all. What is the best solution? 1 replace the boot , 2 replace the complete axle assembly.
I have removed the rear axle of my older MB but not on the front of the E320. Can some one give me some hint on how to remove the axle on the front right.
Thank you
Raybenz
Old 11-01-2009, 08:05 AM
chassis221 chassis221 is offline
your better off having them do it for about 3 hours labor. you can get the boot seperate but you need to remove the outter CV joint to replace the boots. not very hard but a pain without a lift and proper tools.
__________________
Philadelphia, Pa
Certified MB Master
Old 11-01-2009, 08:44 PM
Thanks for the advice, I had replaced the axle on the rear on my old 300SD. I am assuming the procedures would not be different as the rear. I read a tread on the axle and he said he took all the front tie rod and ball joint. Do I need o remove all this parts before I can get to the axle.
On the rear of my older MB, I did not remove any of the ball joint nor any other parts.
Anybody got a copy of the procedures to work on the CV boot.
raybenz
Old 11-02-2009, 06:16 AM
you need to pop out the upper control arm balljoint. but you usually can leave the bottom ball joint attached. pop off the tierod and upper ball joint from the knuckle then slide the axle out . sometimes getting the axle out from under the strut is a pain. which means you might have to loosen the lower control arm so it swings down and out of the way.
__________________
Philadelphia, Pa
Certified MB Master
Old 11-06-2009, 07:12 AM
Default Axle Bolt
Which way to turn the bolt to remove? Do i turn the bolt counter clockwise to remove the bolt?
Old 11-11-2009, 04:34 PM
which bolt. i believe they all are right tight, left loose.
__________________
Philadelphia, Pa
Certified MB Master
Old 11-14-2009, 03:21 PM
cmscott16 cmscott16 is offline
Usually when a boot is torn or loose you have no idea how long it has been that way, gathering small particles and road debris in the cv joint bearings, so it is always recommended to replace the whole joint than to just clamp the boot back down. Also, it is rare nowadays to replace just the bearings in a cv joint axle. Usually you just buy a whole new axle shaft from the parts store, and that's often all they carry anyways.
Tags
benz, boot, class, cv, cvjoint, e320, exle, front, inspection, joints, mercedes, replace, replacement, safety, state
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
Mercedes Benz Accessories
- Brakes & Brake Pads
- Sheepskin Seat Covers
- iPod Car Adapter
- Air Filters & Roof Racks
- Thule & Yakima Racks
Post Release
New Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
