Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Diesel Discussions
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
Old 10-27-2009, 02:19 PM
Jayrow81 Jayrow81 is offline
Default 1982 240d fuel injection problems
I bought a 1982 240d The problem is when I start it cold it starts GREAT.... When the engine gets hot it dies wont restart until it cools down again. I was going to change the fuel filter(plastic one) and the fuel filter(metal canister). Also on the #3 injector fuel return line it has a small leak. The rubber fuel line connecting to he metal return line to the tank also has a small leak due to an old rubber hose. The car sat in my sisters garage for 3(three) years. will this correct the problem or is it another problem... Thanks -jayrow- Register today for free or log in if already registered to remove this ad!
Old 10-27-2009, 08:44 PM
DB444 DB444 is offline
I believe the fuel pump on this car is inside the fuel injection pump.
If the strainer in the fuel tank is clogged could block the ability of fuel pump to suck fuel to the injection pump.
Leaks in the lines can give problems also,so fix them.
I've seen the fuel pump that sucks the fuel from the tank to the injection pump give up ability to suck.
One could replace the injection pump to fix that or install and electric fuel pump to feed the injection pump.
You could clean out the tank strainer and check the other 2 filters.
If you could hitch up a fuel line to the injection pump so 1 end is in a container of diesel fuel and see if the engine still quits when warm.
If it does not quit when warm with this arrangment you'll know the fuel supply has a problem.
If it does quit still when warm could be time for a electric feeder pump.
DB444
Old 10-28-2009, 01:57 AM
Diesel9112 Diesel9112 is offline
If your Hand Primer is the Old Style with the Aluminum body it needs to be pushed all the way down and screwed in to seal properly Also the same Old Style Hand Primer is noted for leaking air when the get old.
I would replace the Fuel Return hose and the 2 pieces of Fuel Inlet Hoses with 5/17 Fuel Hose from the regular Auto Parts store. It is often made by GoodYear and has the number SAE 30R70 and is rated for use with regular Diesel Fuel. Some places sell Gates Fuel Hose; as long as it has the SAE 30R70 it has the same rating.
I would look under the rear of the Car where the Fuel Hoses come out from the bottom of the Fuel Tank. It those hoses are wet with Fuel they are leaking and Air can be pulled into the one that supplies the Fuel. If after draining the Fuel Tank they should be changed.
You might want to look throug these:Repair Links
http://www.peachparts.com/shopforum/...splay.php?f=82
http://www.peachparts.com/Wikka/DoItYourSelf
__________________
84 300D, Volvo 244GL Diesel
Old 10-28-2009, 10:16 AM
Thank you all for the information I will check those problems and get back to you. A local Shop said that they would drain the tank, replace fuel line upgrade fuel injection pump for $400.00 US. Is this a good price for the work that is required. Thanks -Jayrow-
Old 10-28-2009, 03:22 PM
ForcedInduction's Avatar
ForcedInduction ForcedInduction is offline
Thats a horrible price!
The rubber injector hose takes 5 minutes to change all of them and the primer pump takes a whole 15 minutes if you do it the hard way. Parts alone will only be about $35.
Draining the tank is unnecessary unless the hoses are leaking or you're sure the tank strainer is clogged. The strainer is easy to test for; switch the supply and return hoses to each others metal tube and if the problem goes away the strainer is clogged.
__________________
www.youtube.com/Turbo617
Tags
240d, 300d, benz, fuel, hand, injector, install, line, mercedes, mercedesbenz, prime, pump, replacement, return, troubleshooting
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
