new trans slip problem-92'300te
Old Oct 26, 2009 | 09:01 AM
uber124's Avatar
Default new trans slip problem-92'300te
This is a brand new problem. 92 300 te, 148k, trans rebuilt 12k ago. I can feel every shift, but any attempt to accel. will cause immediate slippage in any gear including reverse. It will drive if done very gently. Fluid is clear and correct.
Any diy suggestions greatly appreciated!
Old Oct 31, 2009 | 09:18 AM
uber124's Avatar
Well I first looked everything over, made sure there was no obvious external faults, no plugs disconnected etc., then I drained and replaced trans fluid and filter although it was clean and correct level. I finally brought it to a trans shop and they checked pressures and diagnosed it asa band problem and clutch packs slipping, teardown required to further diagnose.
So I am now on the prowl for a known-good used transmission.
S600 owner
Oct 19, 2010 06:32 AM
cliff
Jan 1, 2009 03:55 PM
knotknowenuff
Oct 9, 2008 09:44 PM
hwaksiliya
Dec 16, 2007 06:03 PM
rr_havuz
Mar 11, 2004 08:04 AM
