Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Mercedes M Class
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
Old 10-24-2009, 12:35 PM
luckyboy134 luckyboy134 is offline
Default Ml270 cdi auto will not kickdown
We have just bought a 2000 plate ML270CDI and it runs great apart from it won't kickdown when you want to acelerate. It has a auto tiptronic box and we took it to a vehicle electrician today and they put it on the computer and it came back with Glow plug malfunction, Intake channel shutoff malfunction and a Accelerator pedal position sensor 1 voltage to high.
Could anyone please help
Old 10-24-2009, 09:44 PM
ForcedInduction's Avatar
ForcedInduction ForcedInduction is offline
Quote:
There is your problem. You'll likely need a new throttle pedal assembly.
__________________
www.youtube.com/Turbo617
Old 10-25-2009, 08:10 AM
Should the kickdown button under the accelerator pedal press down and click back up by hand as this button does not move at all. Can you also tell me where the coolant sensor is as we cannot get the warning light off and it is full with coolant and finally when we press the low range button it just flashes quickly a few times and then goes off.
Thanks for any help.
Old 10-26-2009, 10:37 PM
mbenz80 mbenz80 is offline
Hi luckyboy,
the kickdown button should be clicking back up to its original position, check if the floor carpet it's not in the way. I'm not sure where the coolant level sensor is located. Your throttle body may be very dirty from carbon buildup, not working freely. Also the electronic box on it's side is very simple, 4 wiper style potentiometers giving out difrent voltage reading in certain position. I would try cleaning it all before ordering replacement, they are $$$.
Check your owner's manual for low range shifting, I believe you have to have your car in neutral with brake pedal pressed down.
Bernard
__________________
1999 ML320 162K MILES
1980 280SE EURO W126 157K MILES JUST SOLD
1984 300D TURBO DIESEL W123 SOLD
others:
1988 Chrysler New Yorker Landau 68K miles
2004 Dodge Intrepid 102K miles
Tags
270, benz, body, cdi, clean, diesel, kickdown, landau, manual, mercedes, ml, ml270, owners, throttle, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
