Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Mercedes R Class
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
Old 10-22-2009, 10:07 PM
Bruce01 Bruce01 is offline
Default 2006 R350 rear lights
My R350 has approx. 52k miles and I have replaced all of the 6 tail lights and I am still getting a message from the dash control center stating the lights in the right and left are having issues. Has anyone else had this problem?
Thanks,
Bruce
Old 11-01-2009, 01:42 AM
barkysbro barkysbro is offline
Default This happened to me at the same mileage..
It is a known problem with the tailight circuit board. Apparently the fix is to resolder some loose connections. THe MB dealer in Las Vegas fixed it for me in one day , under warranty, while we were driving through there on vacation in June.
Old 11-01-2009, 08:35 AM
chassis221 chassis221 is offline
needs an updated wire harness and ground. you need to remove a wire from the connectors and insert the wire into a new harness. both sides need the update.
__________________
Philadelphia, Pa
Certified MB Master
Old 11-01-2009, 09:07 PM
Default That sounds like a much more realistic description..
Guess the service writer in Vegas "dumbed it down" for me.
Old 11-13-2009, 09:12 PM
Exclamation R350 2006 rear lights
Thanks for all the inforamtion about the rear lights. It was the rear wire harness for the tail lights. I called MBUSA about this problem and there has been a technical bulliten issued for this problem by MB. They recognize the mechanical and engineering problem and the customer has to pay for the repair? Seriously! It is not the out of pocket expense, it is the added frustration and just owning up to mistake by the manufacturer which should be repaired by the MB.
Tags
board, change, circuit, light, mb, mercedes, r350, tail
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
