Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Mercedes SL Class
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
Old 10-21-2009, 03:19 PM
CoreyJ CoreyJ is offline
Default Pass. Window won't work on 95 SL500 Cab
I have a 95 SL500 convertible that the driver's side window works properly, dropping down slightly when closing with the top up, but the pass. window won't work (it is currently in the full up position). I've tested the window motor and it's not getting any power at the motor. Then by chance after I wiggled some of the top fuses in the trunk area it worked several times then failed - now I'm back to no power. Could this be the power soft top module? and would it affect only the pass. window? I will also try checking for power at the window switch to be sure its not the switch thats failed - but I would guess it requires the logic (and power) from the module to lower the window slightly when the top is up. Any ideas? Thanks! Corey
Old 10-23-2009, 07:29 AM
bobterry99 bobterry99 is offline
Seems to me you know exactly what you are doing. Yes, the top controller could be bad.
The switch inputs a signal to the controller, and the controller powers the motor through the fuse in the trunk. If the soft top is on the car, activating the top control switch should operate the window too, of course.
Old 11-01-2009, 11:21 AM
bonanzapilot bonanzapilot is offline
Please refer to my posting regarding the resetting of the window-up relay. Could not hurt to try the procedure.
Tags
95, driver, forum, mercedes, power, problem, relay, s500, sl500, top, window, windows, wont, work
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
Mercedes Benz Accessories
- Brakes & Brake Pads
- Sheepskin Seat Covers
- iPod Car Adapter
- Air Filters & Roof Racks
- Thule & Yakima Racks
Post Release
New Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
