CLK (W208) full beam not working (but flasher does)
Old Oct 20, 2009 | 04:57 AM
JDMariner's Avatar
Default CLK (W208) full beam not working (but flasher does)
My year 2000 CLK (W208) has a problem. When the lights are on and then you push forward on the stalk to try and select 'full beam' nothing happens. The full beam lights do work if you use the flasher by pulling back on the stalk. This has been an intermittent problem. I've managed to temporarily solve in the past by fiddling with the light selector switch (above the parking brake release), I've a feeling it may be a connection or something behind that rather than a stalk problem?? Any ideas anyone??? Can anyone tell me how to get the selector light switch out to check connections (if you think that may be the prob??)
Is there maybe a relay involved that may be flaky??
Many thanks in advance - MOT is due and obviously would fail currently!!
Old Oct 22, 2009 | 02:29 AM
JDMariner's Avatar
Any help or suggestions anyone? Still no joy from my end, have tried manipulating the rotary switch as much as I can, but not any further forward really - grrrr!!
Jimbob Jim
Apr 4, 2015 09:14 AM
mycarscout
Aug 4, 2010 11:10 AM
87MBZTurbo
Aug 30, 2009 06:06 PM
CLKstuff
Nov 20, 2008 05:00 PM
fly_major_fly
Dec 10, 2005 03:12 AM
