04 s430 AC/Heater fan not working
Old Oct 17, 2009 | 03:22 PM
andys430's Avatar
Default 04 s430 AC/Heater fan not working
Anything to look for, fuse is ok, I am assuming this motor is buried in the dash?
Old Oct 17, 2009 | 05:19 PM
could be water intrusion into the blower box by a clogged water drain under the windshield passenger side under the hood at the firewall. look inside the black grate and see if water is in there. the water spills into the cabin and onto the blower motor. there also used to be a recall on those S classes some years ago for ands updated wire harness to the blower from the fuse box. could also just be a bad blower motor regulator.
Old Oct 17, 2009 | 05:51 PM
andys430's Avatar
The drain was plugged a little bit, I am familiar with that issue, where is the blower motor located? and the blower regulator, thanks for the help...
Old Oct 17, 2009 | 05:59 PM
under the passenger dash. remove the lower dash panel then remove the blower motor cover. the regulator is on the blower motor. you will need torx bits to remove both the covers and the regulator and the blower.
Old Oct 17, 2009 | 06:24 PM
andys430's Avatar
ok thanks, so does the dash piece just pop out or is there screws?
Old Oct 17, 2009 | 06:55 PM
3 or 4 screws and the panel basically pulls down from the front. unhook the wire to the light and maybe the teleaid speaker. then youll see the blower motor case.
Steve's
Nov 6, 2012 09:55 PM
slkrider123
Apr 9, 2012 04:56 PM
patricknif
Mar 4, 2012 06:38 AM
mikem9
Jun 10, 2005 10:56 AM
pseverin
Jan 30, 2005 06:33 PM
