"Reduce Engine Oil" message?
Old Oct 15, 2009 | 07:23 PM
Roy Gardner's Avatar
Default "Reduce Engine Oil" message?
I've started getting a "Reduce Engine Oil " message on my 2003 E320. The first time I got the message, I was driving a freeway speed. The malfunction warning cleared when I slowed to surface street speed.
I had the oil changed today and the message came back at surface street speed. Any thoughts or suggestions?
Old Oct 22, 2009 | 04:12 PM
sal911's Avatar
You may have a faulty engine oil senser or known as sender too. On My E320,2001 it's located inside the oil pan. To get to it you have to dran the oil and take the oil pan off so you can get to the sensor and change it. It runs about $90.00 to $100.00 if you get it online. It's a common problem with these E calss after a few years. If you are a handy man when it comes to car work you can do it yourself. Dealer will change you around $400.00 to do it. check your dealar to see how much they charges. hope this info help.
Old Oct 23, 2009 | 04:23 PM
D.Deelf's Avatar
Okay i am freak out, i turn on my car a msg pops up saying "Engine oil service." I checked my oil, its clean and at a good point. Whenever i start my car it pops back up "Engine oil service"..... what do i do??
Old Oct 26, 2009 | 09:16 AM
sal911's Avatar
Check your engine oil level, make sure it is at the right level.If you have more than the max level reduce it. Or take it back to whoever did the oil change and have them reduce. if that did not work. You may have a faulty engine oil senser which is located inside the oil pan.
nadeem810
Nov 24, 2018 04:50 PM
vip2442
Sep 19, 2006 02:25 PM
sevegolf
Sep 6, 2006 03:29 AM
vip2442
May 6, 2006 02:06 PM
