Chronic Dead Battery, amps at rest?
Old Oct 14, 2009 | 01:08 PM
benzoholic1969's Avatar
Default Chronic Dead Battery, amps at rest?
My battery keeps dying. I've charged it, changed it, still dies. If I don't put it on a trickle charger every night the next day it's dead.
The car is pulling 0.71 amps with everything turned off.
Is this normal?
Thank you,
BKH
Old Oct 14, 2009 | 07:33 PM
what car make and model do you have?
Old Oct 16, 2009 | 11:01 AM
marc2002's Avatar
Same here. 2004 E320CDI. Went to workshop, changed Unit Control Module two months ago, cause of not starting / disabling of comfort system. It seemed to be ok till now. Again, can't start.
Help appreciated, thanks
Old Oct 16, 2009 | 02:28 PM
swanee59's Avatar
Default Battery
If your battery cannot hold a charge with a 0.71 amp draw overnight I would strongly suggest it is not fit for purpose, doesn't matter which model MB a 12 volt battery should easily last over several days at that low amperage.
S.
Old Oct 16, 2009 | 07:24 PM
gilgorm's Avatar
There are a multitude of dead-battery problems on this forum.
If so equipped, check power seat modules, keyless go, and in my own personal case check that the alternator is functioning properly. I had one that charged the battery (after a boost) and then sucked the power out of the battery overnight. A faulty diode in the alternator was at fault.
By the way, a battery that goes completely dead more than five to six times will never hold a charge longterm.
ralphboineau
Sep 15, 2011 09:37 AM
smutny26
Aug 26, 2009 10:58 AM
thelaserguy
Apr 8, 2009 10:39 PM
hollyc320
May 29, 2008 01:41 PM
aqilea
Jun 29, 2007 07:23 AM
