Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Mercedes E Class
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
Old 10-17-2009, 08:10 AM
beef1337 beef1337 is offline
If you don't have time to purchase the tool mentioned above, I tried the plug change technique in benzworld forum sticky http://www.benzworld.org/forums/atta...e-dscf1861.jpg
. You attach a loop of line around the plug wire cylinder. It worked well for me without damaging the wires. The hazet tool would have been useful in putting the wires back on though.
Old 10-18-2009, 10:18 AM
rbp rbp is offline
Default E430
I just got nice tool that I hope will work. I will post my infor once I am done with replacement of my plugs. It is 11" Long Nose Hose Jaw Pliers.
Thanks for the info
Rich
Old 10-20-2009, 07:39 PM
cigaro cigaro is offline
The long nose pliers may not have the angle that you need to get to the spark plug boot to pull it straight out.
I bought a Husky 4-piece double box wrench from Home Depot for $12. It came with 4 double headed wrenches (8-9mm, 10-11mm, 14-15mm, 17-19mm) then used a bolt cutter ($20) to cut half of the 17mm head. The resulted tool looked and worked much like that famous and expensive Hazet # 2771. If you don't have a bolt cutter, a saw might do the job but it takes longer. I was very careful when cutting the wrench's head. The metal fragment would fly out at random. I positioned the bolt cutter onto the wrench, placed a cloth towel over before I cut so the metal fragment would fly nowhere.
http://i35.tinypic.com/5o9rmc.jpg
Old 10-25-2009, 09:04 PM
ohlord ohlord is offline
Default i HAVE`THE SPECIAL 17MM BOOT REMOVAL TOOLS
DON'T WASTE TIME USING PLIERS THEY DON'T GET IN THE ANGLES YOU NEED TO REMOVE THE BOOTS.
YOU DO NOT NEED TO REPLACE THE PLUG WIRES.
THE UPPER WIRE ALWAYS GOES TO THE FRONT PLUG ON EACH CYLINDER AND THE LOWER COIL WIRE TO THE REAR PLUG ON THE CYLINDER.
ngk7090 plugs are undert3bucks
5years or 100k miles whichever comes first,so your plugs are due
No anti seize
ohlord
__________________
ohlord
from the janis Joplin song
Oh Lord won't you buy me a Mercedes Benz
Old 10-28-2009, 12:05 AM
rbp rbp is offline
Default E430
I dit it. I changed all 16 spark plugs (Bosh Platinium2) and I have to admit, it took me almost 5 hours to do it. It wasn't that bad but it took some time. I believe that second time I could do it in 3 hours. I also changed engine oil Mobil1, oil filter and air filter. All part I got for $115.00. Not bad at all.
  #16
Old 11-01-2009, 10:28 AM
dwa1971 dwa1971 is offline
Default changing spark plugs
Since it's probably been awhile since they have been changed one of the easiest ways to change them and get another maintenance item looked after try the following. Take the valve covers off and replace the gaskets and while they are off you can get to the plugs a lot easier. You can also look at some hoses while you're at it since they may need updating as well. Took me no time at all.
dwa1971
  #17
Old 11-09-2009, 09:24 PM
easyrider13 easyrider13 is offline
Quote:
Originally Posted by ohlord View Post
No anti seize
ohlord
I've been using anti-seize compound on plugs going into aluminum heads.
What am I missing?
Tags
2001, benz, change, changing, e320, e420, f8dper, help, mercedes, ngk, plug, plugs, spark, w210, wire
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
