Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Mercedes SL Class
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
Old 10-04-2009, 11:16 PM
brookings brookings is offline
Default If you still have a vibration after balancing your tires
fyi, after replacing my steering damper my vibration problem was cured. I got the part for under $30 on line. a 17mm wrench and a 17mm socket and a ratchet is all you need. wow! what a difference.
Old 10-05-2009, 05:03 PM
silver fox silver fox is offline
Default suspension vibration
Brookings, your comment on the steering damper is great, I had a similar problem and results. However, I had an additional suspension vibration only this was from the rear end. I had the rear wheels balanced twice but problem remained. The tire shop suggested I replace the rear shocks as in an older car [mine a 91, 300sl] the gas pressure in the shocks can become low. The shocks still seem to work untill at a highway speeds the natural small irregularities in the road are not absorbed due to the lower gas pressure in the shock.
I was desperate so replaced the rear shocks....problem gone!
Old 10-06-2009, 02:38 PM
Orb the Impaler Orb the Impaler is offline
I had the exact problem on my old 2000 SLK230 - mine occurred after the damper was replaced and the shop had failed to tighten the bolts.
__________________
2002 SL500
2002 C220CDi Sportscoupe Panorama Evo
2001 Yamaha YZF-R1 - Blue
1999 Yamaha YZF-R1 - Red
2006 Honda CRF450R Supermoto
Old 10-06-2009, 09:23 PM
tightening the bolts sure can help
Old 10-31-2009, 01:36 PM
bonanzapilot bonanzapilot is offline
Here is one more reason tires vibrate after balancing... the newer low profile 245/45/17R and similar sizes tend to separate after a number of years, whether or not they seem worn out. I just replaced two Michelins yesterday because of this problem. They appear brand new, but checking serial numbers, were years old, and separated. I could not see it, but the front end man could.
Tags
190e, 1992, 2001, balancing, car, end, front, mercedes, merdedes, rear, steering, suspension, tires, vibrates, vibrating, vibration, wheels
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
Mercedes Benz Accessories
- Brakes & Brake Pads
- Sheepskin Seat Covers
- iPod Car Adapter
- Air Filters & Roof Racks
- Thule & Yakima Racks
Post Release
New Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
