C Class - Problem with Panorama roller sunblinds
Old Sep 21, 2009 | 10:42 AM
Nick-M's Avatar
Default C Class - Problem with Panorama roller sunblinds
Noted the comments/suggestions posted on problems with the sliding sunroof. My problem relates to the sunblind. I opened the sunblind sometime ago but I now find I am unable to close it. When following the procedure as stated in the manual the sliding sunroof closes but the electrical switch just makes a clicking noise and refuses to close the blind.
Before making what is likely to be a very expensive visit to my local Mercedes dealership I would be grateful for any suggestions
Old Oct 20, 2009 | 03:09 PM
ben19's Avatar
Default Any solutions
did u have a solution to your problem? im havong the same prob but on e320 w211.
Old Oct 20, 2009 | 04:45 PM
if nothing is broken then you need to play with the switch a bit to get it to work, use the switch to vent the roof. then close it all the way. then relaese the switch and then press close again holding the switch. try numerous postions with the swtich and then usually youll be successful with it.
Old Oct 21, 2009 | 07:25 AM
Nick-M's Avatar
Cool
Thanks to Chassis 221 for responding.I did try playing with the switch but unfortunately it didn't have any effect.In the end I was forced to visit Mercedes dealership.They fixed the problem in a few hours at a relatively small cost £65.
Ben 19 - unfortunately as you can see I am no help to you.
Thanks to everyone who responded
Nick-M
Old Oct 21, 2009 | 04:11 PM
ben19's Avatar
Nick M
What did the mechanic do/replace. I wanted to know as I can be aware for them not to rip me off. Thx
Old Oct 23, 2009 | 06:05 AM
Nick-M's Avatar
Ben19 - Set out below is the description of work as set out on my invoice for the job.
"Read and erase vehicle fault memories.Check,lubricate and normalise sunroof.Re-read and erase roof memory"
I hope this is of some help to you
Nick-M
richard65
Jun 20, 2011 01:35 PM
romancagg
Jan 27, 2008 10:43 AM
mbgt
Mar 26, 2006 10:32 PM
racecreations
Aug 6, 2004 04:16 AM
