Om617 Jeep Project
Old Sep 19, 2009 | 11:46 PM
jlguler's Avatar
Default Om617 Jeep Project
Hello,
I am in the process of installing an OM617 into a 1985 Jeep Cherokee. I am debating whether or not to use the stock Benz transmission. I would like to keep the four wheel drive but I am not sure how to adapt the torque converter to the Benz flywheel. The transmission is a Chrysler A904 torqueflite that bolts right to the transfer case. The bellhousing pattern is for the 2.8 GM V6, so the bellhousing to engine adapter would be fairly easy to fab. Is the OM617 externally balanced? If so, maybe a custom torque converter with the Benz mounting pads would be easier? I have seen other Om617 swaps, but they used manual transmissions.
Regards,
John
BenDiesel
Oct 6, 2014 09:08 PM
74dj5d
May 26, 2009 10:22 AM
mbz300sdl
Sep 17, 2008 01:38 PM
QuickE55
Jun 17, 2007 05:47 PM
mbz300sdl
Oct 12, 2005 02:20 AM
