ML 320 crankshaft position sensor
Old Sep 17, 2009 | 12:29 PM
vsalico's Avatar
Default ML 320 crankshaft position sensor
Replaced the CPS on my car about three weeks ago after it wouldn't start and everthing worked fine until today--same problem, turn the key and nothing happens.
Would appreciate help. Thx.
Vince Salico
Old Sep 17, 2009 | 01:59 PM
Vince,
nothing happens mean cranking but no firing or completely dead?
If it's cranking OK, go back and clean harness plug contacts, per my PM.
Bernard
Old Sep 17, 2009 | 07:29 PM
vsalico's Avatar
Default ml320 crankshaft position sensor
There was no cranking of the engine at all--turn the key all the way and the instrument lights were all lit but no sound from the starter. The car started about one hour after it set for awhile and has started since (3x).
Frustrating!!
Vince
Old Sep 17, 2009 | 09:35 PM
From my understanding, when there is a problem with crankshaft sensor, your engine would be cranking fine but ignition coils will not fire because piston position signal would be missing or incorrect compare to camshaft signal and valves position. that means CPS is not your starting problem.
naseeb
Oct 24, 2011 08:22 AM
vsalico
Aug 28, 2009 09:47 AM
vsalico
Aug 25, 2009 09:14 AM
CCCP
Feb 25, 2005 10:41 AM
sdanville
Sep 20, 2004 04:30 AM
