Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Mercedes SL Class
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
Old 09-15-2009, 09:11 PM
Grumpy old man Grumpy old man is offline
Default SL Repair manual
I am in process of resurrecting a 94 SL. I just put the engine back together and it runs but poorly. It acts like the valve and/or ignition timing is late. I have been going crazy all summer trying to find a complete repair manual for the car including all engine specs, in particular right now valve timing spec, and all the vacuum and wiring diagrams. I have purchased three "complete" repair programs on DVD and found them to be something quite short of complete. The questions I have at this time are, does ANYONE out there in Mercedes land know where I can purchase a repair manual for an SL and short of that is there somewhere that I can find cam timing spec so I can check the valve timing with a degree wheel and dial indicator. Also I recall seeing somewhere that engine codes can be found without a scan tool. Where can I find the procedure and a code chart as it does trigger the check engine light after driving it for an hour or so. It is apparently not a hard code because when you shut it off the light resets and does not come on again until you drive it for a while. Thanks in advance for any help you can offer.
Old 09-22-2009, 02:05 AM
brookings brookings is offline
www.alldata.com
Old 10-13-2009, 02:59 AM
rosscolor rosscolor is offline
Default engine specs
I've got the DVD's also.......fairly involved as you stated, but I think I can come up with the degrees when Intake valve begins to open at a certain tolerance like .015 inches.....I will check email me at Rosscolor@att.net tomorrow
Old 10-13-2009, 03:30 AM
Thumbs up cam timing for the V-12 motor only
dial indicator will show 2mm lift and Intake valve opens at 34degrees after TDC I am assuming you are proficient at this timing thing (it is tough to do it correctly)
this applies to the 120.980 and 120.981 motor
Old 11-03-2009, 10:22 PM
nighthawk nighthawk is offline
i just purchased a 90 500SL and i am also looking for a repair manual. Mercedes Canada wants 200 $ for the DVD. Is it worth it? i have a few electrical issues with the car such as roof and flickering dash lite. i would like to get at least a copy or the wiring diagrams.
Tags
107, 120981, benz, engine, forum, forums, manual, mercedes, mercedesbenz, repair, roof, service, shop, sl, top
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
Mercedes Benz Accessories
- Brakes & Brake Pads
- Sheepskin Seat Covers
- iPod Car Adapter
- Air Filters & Roof Racks
- Thule & Yakima Racks
Post Release
New Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
