2000 C230 Kompressor Oil Leak??? Help!
Old Aug 30, 2009 | 08:46 PM
mbzachs's Avatar
Default 2000 C230 Kompressor Oil Leak??? Help!
Ladies and Gents,
I have a 2000 C230 Kompressor and after sitting for a week in my garage I noticed a fairly large oil spot under the car. The oil level is low and I got an oil change about two months ago. I attached a picture of the general area where the leak is coming from. I checked the oil pan and there isn’t much evidence that oil is leaking around the plug but there is a lot of oil around the areas I have marked in red on the black "pan" looking part aft of the oil pan. Can someone tell me what this part is and what is above it? Does anyone have suggestions on steps I could take to deduce this problem?
Thanks so much!!!
Z
Old Aug 31, 2009 | 06:35 PM
xs1's Avatar
xs1
If the fluid is dark red/ brown it is the trans electrical connector seal/socket.. Very common problem...see the black and brown electrical connector??....there is a rubber 0-ring type seal on the inside of the connector...the seal is part of the socket...u can pick up the socket at the dealer for around $40, it comes with a new seal. recommend having the fluid level checked after repair..
Old Sep 1, 2009 | 11:28 PM
Rockerfella174's Avatar
hi,
XS1 is correct it 's a common "o" ring problem that causing the oil leakage ..it happen almost every 211 e class & 220 s class ..that i encounter do top up the oil before u send over.
minor repairs ...
good luck!!
Old Sep 3, 2009 | 08:43 PM
mrcoyote's Avatar
Talking
Exactly what you guys said. Happens like clockwork on this model car.
orcldba8
Sep 11, 2013 11:06 AM
red92xblue
Apr 26, 2010 07:10 AM
rx7pro
May 3, 2009 07:45 PM
misslivvy
Sep 12, 2008 11:05 AM
drblank
Jan 9, 2007 10:33 PM
