87 300 Diesel - Pre-glow light not working...does not start when cold? PLEASE HELP
Old Aug 28, 2009 | 10:04 PM
87MBZTurbo's Avatar
Default 87 300 Diesel - Pre-glow light not working...does not start when cold? PLEASE HELP
Hi All,
I have a 87 Diesel (SDL). Its Pre-glow indicator lamp on the dash stopped glowing after the key is turned on, hence it does not start when the engine is cold. What could the issue be and how can I fix this problem? Please help.
Old Aug 29, 2009 | 12:36 PM
87MBZTurbo's Avatar
Thanks very much for the prompt response. I checked the fuse box and there was no fuse for pre-glow indicator lamp and all the fuses in the box seem to be ok. Anything else I can try?
Old Aug 30, 2009 | 06:06 PM
87MBZTurbo's Avatar
Thanks for pointing me to the GP relay box with a photo. The relay strip fuse (silver bridge) appears new and intact (not broken). Also, there appear to be no burn marks inside the box or any corrosion on connectors and pins. Anything else I can check?
Also, another issue I discovered is that the fan in front of the radiator remains on the whole time while the engine is running. I believe it is only suppose to turn on when the engine is hot.
patricknif
Mar 4, 2012 06:38 AM
dougrose
Nov 5, 2008 06:36 PM
lovedabch
Jul 12, 2007 10:29 PM
gruber300
Mar 27, 2007 05:29 PM
Xacting
Oct 18, 2006 12:42 PM
