Coolant in windshield washer tank 1990 500sl
Old Aug 28, 2009 | 11:12 AM
johnkoper's Avatar
Default Coolant in windshield washer tank 1990 500sl
New to group with new used 1990 500 sl...
Appear to have Raditor fluid and very warm water in Windshield washer fluid (white) container. any suggestions where issue is?
Thanks...
Old Aug 28, 2009 | 02:33 PM
johnkoper's Avatar
Default found why Coolant in windshield Water bottle
Found my own answer.. 1990 500 sl uses a heating coil (via engine coolant) in the water for Windshied water container to prevent Freezing... This coil can leak.. Solution.. Bi-pass coil with Copper fitting outside of Water bottle... or replace coil... bi-pass is answer as freezing is not an issue...
Old Aug 29, 2009 | 01:49 AM
brookings's Avatar
there is a composite valve inline on the heating coil down inside the reservoir. with age and sometimes with the help of putting the wrong windshield cleaner in the reservoir will cause it to crumble. don't use household cleaners such as windex. there's ammonia in those products and not good for anything in the system.
Dobschcan
Jun 4, 2011 07:30 AM
mnstang
Aug 29, 2006 08:32 PM
posmaxx
May 11, 2005 12:18 AM
honeybee
Mar 14, 2004 07:10 PM
honeybee
Jan 18, 2004 02:16 PM
