Can't Find Transmission Drain Plug
Old Aug 24, 2009 | 11:53 AM
karenrc's Avatar
Default Can't Find Transmission Drain Plug
I have a 2002 SLK32 AMG that has just hit 30K on the factory transmission oil fill. I would like to change it but cannot find the drain plug. I have changed tranny fluid many times on previous Mercedes vehicles but they all had plugs and easy to get at filters.
Does anyone know how I should go about doing this? I have a lift in my basement but I am not looking forward to loosening the pan bolts to drain it.
Old Aug 24, 2009 | 06:46 PM
brookings's Avatar
normally you would pump it out through the dip stick pipe then remove the pan to replace the filter and then rotate the torque converter to show the plug to drain it too after removing the inspection cover..
Old Aug 25, 2009 | 10:32 AM
karenrc's Avatar
OK, thanks. I'm away from home at the moment but will check on the torque converter plug. I cannot recall whether this one has a plug or not. All the other MB's I've owned had one.
I've always changed tranny fluid and filter every 30K and am not about to let this one go further.
Old Aug 27, 2009 | 02:03 AM
livefreeordie's Avatar
Your better off dropping the pan, the drain plugs are very hard to remove and you may strip it.
xjvoorheesx
Jul 31, 2006 04:08 AM
xjvoorheesx
Jul 31, 2006 04:03 AM
pgardell
Feb 18, 2004 08:03 PM
cmscott16
Jan 8, 2004 09:16 PM
