First post, c280 idle problem with clean maf
Old Aug 4, 2009 | 09:53 PM
Fizoust's Avatar
Default First post, c280 idle problem with clean maf
I have a Mercedes Benz C280 and when i start the car it idles fine. When I drive it down the street and stop and a stop sign it idles really rough. It acts almost as if it is surging.
When i start to accelerate it feels almost like a knock, then hesitates, when i finally does accelerate when i stop again at a stop sign same symptoms of surging idle.
Is it possible carbon build it?
After reading a few posts I decided to clean my maf. I used rubbing alcohol and a qtip and gently scrubbed it. I then drove the car and it had the same problems.
I am open for all suggestions, please help.
Old Nov 26, 2009 | 09:58 PM
billgracyleung's Avatar
Default C280 idle problem
You may want to check and clear the mass air flow sensor. If it not helping the problem try to change a new mass air flow sensor, aroung $300 for after market.
Bill Canada
Old Nov 29, 2009 | 10:17 AM
platonmind's Avatar
Default Mass Air Flow Sensor Cleaner
www.performanceproducts.com sell Mass Air Flow Sensor Cleaner for 10.99 plus S & H. or you can call 1.800.243.1220
Wedowee
Jul 9, 2010 09:12 PM
afinepoint
Feb 16, 2010 01:55 PM
Abye
Feb 4, 2008 02:04 PM
PBI 2001 C320
Jul 18, 2006 06:34 PM
kimos
Jan 14, 2005 08:19 PM
