Oxygen Sensor
Old Aug 4, 2009 | 09:50 AM
Dewey00's Avatar
Default Oxygen Sensor
The 02 light comes on daily in my 87 260E, I would like to clean or replace the sensors. so my question is, where are they and how should I clean them?
Old Aug 4, 2009 | 10:45 AM
BuyMBparts's Avatar
Default oxygen sensor
You have one sensor on that car and it is located on your catalytic converter near the front.
Old Aug 4, 2009 | 09:16 PM
phillip jones's Avatar
replace it very easy 22mm spanner or 7/8 undo fom exhaust pipe near to cat undo wire .
buy universal bosch unit 50 euros ish and follow the instructions on leaflet on how to connect wires.
you will need to tell your factor if it is 3 wire or 4wire good luck
Old Aug 22, 2009 | 08:16 AM
Dewey00's Avatar
Thanks,
Actually I went back in my records and found that i had the sensor replaced, but the issue is still occurring, with sputtering and some stalling. The shop that i take has no idea what the problem is,Im at a loss.
Old Aug 24, 2009 | 10:15 PM
Rockerfella174's Avatar
Clean up your throttle body & replace the o2 sensor ...for some cars there are 2pcs... i would just replace all of it... an aging sensors tend to break down
hope it works out
spyderman_j
Jul 7, 2007 02:02 PM
Mecke07109
Apr 30, 2006 08:10 PM
taejlee
Feb 1, 2006 04:33 AM
craig from iowa
Jul 11, 2005 02:22 AM
kburks1230
Aug 19, 2004 10:57 PM
