C220 CDI Windows and Central Locking Fault
Old Jun 14, 2009 | 04:46 PM
stuart2106's Avatar
Default C220 CDI Windows and Central Locking Fault
C220 CDI W202 Year 2000
Hello,
Two weeks ago I came back from holiday and pressure washed my car. The next morning I lowered my electric windows slightly on the way to work. At work my passenger window would not close. (no response from the switch) my Central locking would not work either.
I checked all the fuses and relays in the engine compartment and the box in the boot...All Okay
Three days later, my drivers window would not lower. I have had a suggestion from a very experienced person on another forum that I could have got water into the door controller ECU's, but I have had the passenger door panel off this weekend and they are bone dry. Furthermore, they do not look to be in a place where there could be an ingress of water..
Can anyone please help? I am out of ideas
Old Jun 24, 2009 | 02:42 PM
Demetrios87's Avatar
I think it might be the fuses. you should checked them again. because i had the same problem in my merc.
the switch from my right back door came of and i didnt knew it.
they were burned and i couldnt open the car either the windows !!!!!!
I dont think water went in but you never know!!
If that is the case then you should take of the door panels and check it!!!!
Old Jun 25, 2009 | 04:58 AM
stuart2106's Avatar
Thanks Demetrios87
I will check them again.
Stuart
Old Feb 28, 2010 | 10:39 AM
tricky ricky's Avatar
Hi having the same problem as you, i think? My cental locking is not working (have just bought the car) and the elec windows are going down ok but very i have to repeatedly press the button to inch the way up in order to close them. Did you get the problem sorted on yours thanks Richard
BristolMercedesMan
Jun 6, 2010 07:51 AM
delboy277
May 12, 2009 05:19 AM
jimmys
Apr 30, 2007 10:14 AM
keith_johnson1967
Aug 10, 2006 08:42 AM
forfar4
Jul 4, 2004 02:42 PM
