C280 Power Steering Whine
Old Jun 14, 2009 | 03:27 PM
C2801997's Avatar
Default C280 Power Steering Whine
The power steering on my 1997 C280 (112K Miles) makes a whining/humming noise when I turn all the way to the left or right at about 20-30 MPH- There is no sound unless it is a sharp turn requiring the steering wheel to be fully turned. Otherwise, it is fine on straight drives and light turns.
I am thinking it has something to do with the Power Steering Pump- If anyone had this problem and could shed some light on solutions, that would be great.
Old Jun 14, 2009 | 03:44 PM
monoped's Avatar
Exclamation
Most if not all fluid power assisted steering will make this nose when pulled against the lock-stops, just ease the weight off on the steering wheel and it will stop. If you persist in pulling hard against the lock-stops you may eventually do damage.
Hope this helps,
monoped
Old Jun 14, 2009 | 06:02 PM
Boogaboo's Avatar
Smile
I have the same thing with my C230 2002. I'll let you know what it is after my mecanic look at it.....cheers....hope not to expensive.....
Old Jun 16, 2009 | 01:24 PM
C2801997's Avatar
Thanks, Boogaboo and Monoped for your inputs. The reason I was concerned is because this noise was not there until about an year ago- I was worried the pump is on its way out!
Monoped, I'll wait to hear what your mechanic says. Thank you.
Regards
Old Sep 16, 2009 | 01:12 AM
Boogaboo's Avatar
My mecanic looked at it...change the power steering fluids....Noise is still there....i'll go back this time this week and let you know if something else appear...
cheers
Old Dec 11, 2009 | 09:37 PM
AMG_Wolf's Avatar
Smile Lucas Oil Product Fixed Power Steering Whining in C32 AMG
I was experiencing whining from the power steering of my C32 AMG. I tolerated it for several months until I searched the forums about the problem. I checked the power steering fluid in the reservoir and found that it was very low. Deciding on the power steering fluid was the next challenge, since I did not want to depend on getting MB power steering fluid from the dealer. I read on the Lucas Oil website that someone tried the Lucas Oil Power Steering Stop Leak on an SLK320 and was happy with it. I picked up a bottle from Pep Boys and poured it into the reservoir to the max level. The whining went away. The power steering now feels smooth. Hopefully, the stop leak fluid will fix any leak that is probably there.
Old Jan 8, 2012 | 10:31 PM
Niko81's Avatar
I have a C280 and cannot find where to fill the power steering does anyone know where this is located
pseverin
Jul 22, 2007 07:35 PM
silversurfer
Jul 27, 2005 03:40 PM
silversurfer
Jul 27, 2005 01:54 AM
JLHowie
May 3, 2005 07:22 PM
johnr
7
Jul 9, 2004 06:46 AM
