CLK320 Gearbox Question
Old Jun 8, 2009 | 11:00 PM
JTC's Avatar
JTC
Default CLK320 Gearbox Question
I have a 1998 CLK 320 Elegance with the standard 5 speed Auto box. I've had the car for about 5 weeks but it seems the gearbox is a bit schizophrenic. I've noticed that under hard acceleration the engine revs to about 5000-5500 rpm and then it doesn't want to go any higher, instead the car starts jerking and the engine keeps revving as if it wants to upshift but can't. I then have to ease off the throttle and then accelerate again and it carries on fine. Is this normal or have I got a potential fault? I've only ever driven BMW's in the past and they never had this issue. I used to be able to drop the hammer and the gearbox would deliver power smoothly across the rev range without any jerkiness. The CLK's gear changes are anything but silky. I was told by the previous owner that the gearbox has to adapt to my style of driving and this jerkiness will sort itself out in time but I don't buy it. Any thoughts?
Old Jun 12, 2009 | 01:12 PM
JTC's Avatar
JTC
The MAF sensor needed replacing. Did that. Also added in a Throttle body reset and the car is like new. Revs all the way up to the limiter with no problem.
therichzone
Dec 28, 2008 11:01 PM
gclassmerv
Nov 7, 2007 05:57 AM
pram82
Jan 23, 2006 07:01 PM
pram82
AirRev
Jul 19, 2005 07:51 PM
