"Service Threshold Reached"
Old May 23, 2009 | 08:44 AM
leshchuk's Avatar
Default "Service Threshold Reached"
Got a E500 211. Have a code for brake system T249F "Service Threshold Reached". Not sure what to do...Thanks in advance...
Old Oct 9, 2009 | 12:12 AM
Rockerfella174's Avatar
Unhappy Service Threshold Reached
Hi Leshchuk,
My E wdb 211 046 too are having the same problem code : C249f Service threshold reached
i too still waiting for a reply
hope some one can help us out..!
rockerfella174
Old Oct 11, 2011 | 03:25 PM
eastwestauto's Avatar
The threshold that is referenced by that code is for the brake pump staying on too long before building pressure. May need assembly. If you retrieved the code then your mechanic can communicate with the SBC hydrolic system and replace unit and bleed. Good Luck!
Old Oct 11, 2011 | 04:45 PM
Originally Posted by Rockerfella174
Hi Leshchuk,
rockerfella174
call the dealership. that very well could be warranty. they are warrantied for life or 10 yrs i think. you need a new SBC brake pump.
Old Oct 13, 2011 | 08:16 PM
sonny27's Avatar
Default chassis221
Hi chassis221 do you have a number to contact you? I need service on a 2006 e350 please call me at 267-333-3289 Sonny or : cruzmcauley@yahoo.com
Old Oct 13, 2011 | 08:17 PM
sonny27's Avatar
please call me 267-333-3289 sonny i need service on a 2006 e350
Old Dec 20, 2013 | 12:41 PM
luweegy's Avatar
Default AS replaced how do I reset the codes
I need info on how to reset eveything now that I put a new ABS pump in which Benz said was out of warrenty. The red no drive light is on in the circle and I have 3 codes which I will retrieve and add to this post.C1617,C21C,C26EC
Old Dec 20, 2013 | 06:58 PM
You need to clear the fault codes to get the lights to clear. Is this a car with SBC braking system? Who installed the part?
Old Dec 21, 2013 | 12:31 PM
luweegy's Avatar
Yes it is.My Benz dealer in Denver said it was out of warrenty.So I bought the part and installed it.I've tried to dissable the system to bleed it with my Solus Pro and it never completes the cycle and says cycle key and try again.I removed the ground on the trunk battery befoer I did this. My Email is evilzr1@gmail if that is easier for you.Thank you for the help. Finally got it to Activate and all is good.
omer123456
Jun 5, 2013 01:06 PM
raltherr
Nov 21, 2010 10:23 AM
PeterTaps
Feb 7, 2010 03:20 PM
mrtennis27
Jun 19, 2009 02:11 PM
Benz09
May 22, 2009 07:03 PM
