Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Mercedes E Class
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
Old 05-15-2009, 06:31 PM
J83A0W80E J83A0W80E is offline
Default Weak fuel pump?
Hey all,
I've had this car for a few months now. Got it from some guy who had it sitting since '05. It needed head work done so I go that squared away and now that it's back together (after a few months) it doesn't want to start. There is fuel going to the injectors but thats where it stops. I took the injectors out and did a nice thorough check to see if they were clogged or not, they were not clogged, so my guess is that the fuel pump is going bad and can't get enough pressure into the system to make the valves move. It's a 1988 300E Saloon with the M103. It has mechanical injectors. I checked the timing three times since and it hasn't skipped at all and the spark plugs are in their correct places (as well as brand new with new wires) and there is fuel in the tank about 5 gallons. It seems though that I might not be getting enough pressure in my system to have the fuel spray through the injectors. I hear the fuel pump working when I turn the key to the on position, but the car refuses to start, and the fuel stops at the injectors which aren't clogged or seized up. No leaks anywhere either. So should I do a pressure test and go from there?
Old 05-15-2009, 09:00 PM
chassis221 chassis221 is offline
i think you should first spray some starting fluid into the throttle body and try to start it. to see if it will start and run, do you have enough battery power to start the car. is it cranking fast enough? is the engine getting spark? i would go with a new pump..actually your car has 2 of them i think and a new fuel filter to start.
__________________
Philadelphia, Pa
Certified MB Master
Old 05-15-2009, 09:13 PM
I tried starting fluid, it starts with that but when all the fumes are used up it shuts off, I have spark, it cranks fast enough, theres enough battery power cuz I keep it charged. I tried it all already, all I can think is that the fuel pump is going bad or something along those lines.
Old 05-15-2009, 09:34 PM
mbenz80 mbenz80 is offline
These older fuel pump are tested not by pressure but by volume. The pump should give you about 1L (qt.) of fuel in 30 seconds from supply hose removed from fuel distributor. Mechanical injectors need about 50-55 psi to operate. Check screen for dirt inside the supply hose inlet of the fuel distributor, checkvalve right next to the inlet (if it's stuck open, your fuel is flowing back to tank) or warm up regulator screwed to the side of engine (if your M103 is equiped with it, my M110 is). There is also screen inside of the input hose fitting, as in the fuel distributor. Rust from lines could of brake loose after sitting for so long and moved towards the engine. Good luck.
__________________
1999 ML320 162K MILES
1980 280SE EURO W126 157K MILES JUST SOLD
1984 300D TURBO DIESEL W123 SOLD
others:
1988 Chrysler New Yorker Landau 68K miles
2004 Dodge Intrepid 102K miles
Old 05-15-2009, 09:41 PM
Yeah I was reading up on about the 50 psi for the valves and stuff just now. I'll be sure to check all that on Sunday, and I'll give a verdict then, thanks a bunch.
Old 11-01-2009, 03:14 PM
Default I'm stupid
So...I've been gone for a few months on business and well I was going insane as to what could be the reason why it won't start...so after pulling out all my hair I finally got a break to go home and the first thing I did was open up the hood, and I realized that a vacuum line was missing from the intake manifold and valve cover...I bought a new one and when I tried to crank it over viola it was alive again...I'm a complete moron...but hey it now runs and works...however it still needs much TLC because of the owner before me didn't care much about it obviously...so I still have a lot of work ahead of me, my questions is, what's a good after market exhaust I should put on her?
Tags
1988, 300e, bad, battery, benz, brand, car, class, clogged, filters, forum, fuel, mercedes, presure, pump, shuts, weak
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
