my 97 e320 is doing rough idle and I need help...
Old May 6, 2009 | 10:01 PM
madameboba's Avatar
Default my 97 e320 is doing rough idle and I need help...
Hello everyone,
I have a 97 E320 has no issue for a year and today it deceided to vibrate and shut off engine near my home.
I restarted the engine it idle rough and feels weak with louder engine sound. It does not produce extra noise just louder engine. When I restarted the engine "check engine" and "engine electronic" warning came on.
It is spark plug or wire needs to be replace, and is it something I can fix.
Thanks for your help..
Peter
Old May 8, 2009 | 12:52 PM
madameboba's Avatar
I just replaced all plugs it got a little smoother but the rough vibrate still there, it feels like a cylinder is not working/spark ?
What else can I do?
pc
Old May 8, 2009 | 05:42 PM
vernon97e420's Avatar
Default Ignition coil.....
I had this at least twice in the past 2 years. Please check your ignition coils. There is probably one that is bad ($80).
Hope this helps.
Old May 8, 2009 | 07:49 PM
ive seen many people who get bad fuel that causes rough idle and misfireing. did it just happen all of a sudden? the wires are usually a primary cause of engine smoothness. maybe maybe a blown out motor mount... that wont really cause a misfire but the engine will vibrate more.
Old May 10, 2009 | 12:17 AM
madameboba's Avatar
Thanks for reply,
I would try to find out if it coil gone bad tomorrow. I refueled to top last week and it was down to less than 1/4 when this happened, does it take a 3/4 tank to cause problem? Please advice.
Thanks again guys.
PC
Old May 11, 2009 | 11:32 PM
Go to any auto parts store and have them scan it for free with OBDII scaner to see, what type of codes you have and what cylinder no. is misfiring.
lashare
Feb 17, 2011 08:16 AM
too_juicey
Nov 4, 2008 08:39 AM
dis614
Jul 12, 2007 03:39 PM
fay3131
Sep 6, 2006 12:48 PM
