Erratic engine temperature on '81 300D
Old Apr 21, 2009 | 12:37 PM
djgonzo's Avatar
Default Erratic engine temperature on '81 300D
My engine temp is running consistently higher than normal. Usually it is around 80-90c and has always fluctuated a little while driving but currently the temp is at or above 100-110c consistently after warming up. In addition, the temp gauge is moving much more frequently as in dipping or jumping 10 degrees every few minutes.
The weather has warmed up recently (I live in SoCal) but I don't think this is the issue. This morning on my commute to work the temperature outside was in the high 60s low 70s and my engine temp was hovering above 100c (the notch above 80).
Coolant level is fine, no leaks. What's going on?
Old Apr 22, 2009 | 05:19 PM
djgonzo's Avatar
Go to a car wash and clean out the radiator from both sides. If that doesn't fix it then the next step is to replace the thermostat and use new coolant.
That's what I figured would be the first step, radiator flush + replace thermo. Thanks!
iloveoldmercs
Aug 20, 2011 03:01 AM
builderdude
Sep 16, 2010 11:17 AM
FEZ
Sep 9, 2005 03:07 PM
kustom81
Apr 1, 2005 11:43 AM
porscheturbo
Feb 24, 2004 09:12 PM
