E230 engine/gearbox problem
Old Apr 3, 2009 | 05:39 PM
skar23's Avatar
Default E230 engine/gearbox problem
Hi can someone please help?? I have an E230 auto 1995 model with round headlights.After driving vehicle for awhile after setting off from a stop it blows out clouds of whiteish smoke.It's not using any water,at max and clean,not using any more fuel than usual but is using gearbox oil with no visual signs of leaks and oil level is going up..Any help would be much appreciated.Many Thanks
Old Apr 18, 2009 | 10:12 PM
Brokendriveshaft's Avatar
You probably have a blown headgasket. I know you say you are not using water, but you are gaining fluid in the crankcase from somewhere. Transmission fluid has no way to get in the engine. Plus white smoke is most likely water. Does your oil look milky?
Old Apr 21, 2009 | 11:12 PM
I'm not sure on your model but I would check if the gearbox and engine oil are not sharing same radiator for cooling engine oil and automatic transmission fluid. There could be internal leak in your radiator. On my 80 280SE the engine oil has separate radiator and engine coolant and transmission are sharing same radiator.
Old May 26, 2009 | 10:32 AM
skar23's Avatar
Hi guys thanks for the replies.Head gasket already been changed and water is still clear,no the oil and gearbox dont share same coolant radiator.Have checked vehicle over again today and found a vacuum pipe that comes off cylinder head close to injectors and feeds down to gearbox is drawing up the gearbox oil into the engine but i dont know what the unit it is connected to on the gearbox does,small cylindrical shaped unit with a white cap .Any thoughts would be much appreciated.Many Thanks.
Old Sep 11, 2009 | 08:26 PM
Brian Murff's Avatar
I have a 1997 Mercedes e230, just started to notice it doesn't like to change gears when its cold and when they finally do change its rather sudden, any ideas?
Old Sep 15, 2009 | 11:33 AM
Mambo's Avatar
Default Gearbox
Had a similar problem a long time ago. Changed the gearbox filter, changed the oil and the problem was solved. You may want to try to do the same, it is not a costly affair.
________
Avandia settlement info
Old Aug 7, 2010 | 04:06 PM
senau's Avatar
hi gus my e230 is not changing gears in a normal way it skips some gears.fist it was on limp mode.gearbox changed now a new promblem started it just changes down buy its while accelerating and this causes the car to skid and brakes.thus 1999 model
Old Aug 16, 2010 | 03:45 PM
senau's Avatar
hi guys here are the fault code e230 1999 model,055,147 and 151 please can any one help.when you delet this code the car changes normaly,only few days like 2 days
then the codes are back.the car will be in safty mode.senau.chas 210
Old Sep 3, 2010 | 09:04 AM
I believe you talking about modulator vacuum valve, not too expensive, about $40 to replace.
Old Oct 1, 2010 | 01:54 PM
rickyb's Avatar
shift module if its bad it leaks trans fluid wich the vacum sucks up to intake manifold and it gets burned with the fuel and blown out the exhaust looking white
simonttl
Nov 25, 2014 02:39 AM
amr_shahzad
May 15, 2014 06:01 AM
asiatiger88
Apr 4, 2011 10:42 PM
kmac
Feb 19, 2011 05:18 AM
NIPPY
Jul 19, 2010 08:31 AM
