e400 idle surging, hesitation
Old Mar 9, 2009 | 12:16 AM
psychotuner's Avatar
Default e400 idle surging, hesitation
1993 3.2L 300E 4 door
Hello guys,
Im trying to help my roomate out, of course I am the guy who works on cars got conned into figuring out what's wrong with his car, however, I know nothing of Mercedes...
Here is the problem from what I know,
#1 Basically the car idle surges up and down up and down.
#2 And there is a problem with the gas pedal, when you mash on the pedal, the car doesnt go anywhere, it doesnt rev up, it just doesnt go. You have to let your foot of the gas and press back down on it till it decides to drive.....
The car does not emmitt any Check engine codes, but the bulb may be popped?
This is not an OBD seres computer system so I do not know how to check for the trouble codes..
Im not sure if these 2 problems are related to one specific malfunction, but this is what I have done so far..
Cleaned the MAF sensor ( or whatever Mercedes calls it) The Sensor on the intake pipe.
I checked the throttle cable and it is not sticking or anything, seems to be functioning properly.
My thoughts are TPS sensor, does it have one? Since I do not detect any throttle bodies...
IACV,does it have one?
I guess my first initial step is to find the trouble codes.
Any help is greatly appriciated!
This is a 1993 300E 3.2L 4 door
Old Mar 12, 2009 | 12:13 AM
top, anyone ?
Old Mar 12, 2009 | 08:02 PM
MASKA's Avatar
Cool surging
Sounds like a BAD case of OVP relay failure !!
Old Mar 12, 2009 | 11:59 PM
Im sorry, it's a 1993 300E 3.2L
eleborate on this OVP relay ?
Old Mar 14, 2009 | 04:21 PM
MASKA's Avatar
Cool Ovp
Its the Over Voltage Protection relay; located behind the Batteries firewall
Old Mar 14, 2009 | 04:35 PM
dondong's Avatar
Hello guys,
CHECK your Engine wiring Harness.... that's what I've found on my car with only 101K miles
Old May 22, 2009 | 12:27 AM
so this OVP sensor needs replaced ?
Old May 26, 2009 | 07:58 PM
top, idle surging always.
Old Jun 21, 2009 | 01:17 PM
top, what do you guys think?
Old Jun 22, 2009 | 06:34 PM
MASKA's Avatar
Man ; What are you on !!
MWK220
Jun 2, 2010 09:25 PM
Hot Rod Ron
Jun 13, 2009 04:25 PM
oregonboy
May 2, 2008 06:18 PM
Turborado
Apr 9, 2007 12:29 AM
Turborado
Apr 2, 2007 07:43 PM
