Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Mercedes M Class
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
Old 10-12-2009, 08:31 PM
onitti onitti is offline
Default egr tube cleaning
I want to clean my egr tube.. My question is am I able to remove the tube only without taking the whole valve off with it? Register today for free or log in if already registered to remove this ad!
Old 10-13-2009, 10:26 AM
mbenz80 mbenz80 is offline
Yes, you will be able to take just the tube out, but you have to manuver little with it ones it's loose, since it has a bent to it. Loosen it up at the EGR valve first, then at the intake manufold. Watch for the thin gasket between tube flange and manufold. Mine was clogged completely.
__________________
1999 ML320 162K MILES
1980 280SE EURO W126 157K MILES JUST SOLD
1984 300D TURBO DIESEL W123 SOLD
others:
1988 Chrysler New Yorker Landau 68K miles
2004 Dodge Intrepid 102K miles
Old 10-21-2009, 09:09 PM
Amopower Amopower is offline
Do you have to work under the engine to get to the EGR valve and tube?
Old 10-22-2009, 12:26 AM
No, but over the top of your engine behind the right side cylinder bank next to throttle valve body. Easy task, half hour and you done. Here is picture of my tubing at about 150K miles, it was completely shut closed!
__________________
others:
Old 10-22-2009, 02:50 PM
thanks, do you recommend buying the new tube and gaskets and be done with it? I see some other members attempt to clean it out with Gummout, not sure if that is effective or not and whether you can really get to all the walls inside that tube that way. I just ordered a new tube and gaskets anyway, for 100 bucks what the heck......which includes me ordering the brake light switch too, to eliminate the left two brake light warnings on the instrument cluster. (or so they say on here...)
  #16
Old 10-22-2009, 09:15 PM
I installed new tube and gasket, it will be a lot harder for the carbon to stick to it and start acumulation. I replaced my brake light switch last week, it was $12 from dealer.
__________________
others:
  #17
Old 11-02-2009, 08:09 PM
Does the part on the attached image need replaced too? I saw another site that said it should be, as it may be brittle and break. If so, what is it called and does anyone have the part#?
  #18
Old 11-03-2009, 10:22 AM
I cleand my egr tube yeterday and it was completely clogged. I don't know what that part in the picture is but I didn't change mines.. in my opinion if its damaged then I would replace it but mines looked fine..
Tags
1999, 2001, 320, 99, cleaning, egr, erg, mercedes, ml, ml320, pictures, rough, running, sensor, valve
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
