Mercedes e320 timing belt change.
Old Sep 4, 2008 | 01:22 PM
topbuzz's Avatar
Default Mercedes e320 timing belt change.
Hi Im new to Mercedes, so i would like to know if my 1996 e320 is driven via chain or belt driven, and if so when is the recomended milage for changing it? as i think the dealer was not truthful,hesaid it was chain driven. It has just gone over the 90.000 miles and has full Mercedes service history.
Many thanks Paul.
Old Sep 4, 2008 | 04:05 PM
ohlord's Avatar
Banned
Default RE: Mercedes e320 timing belt change.
M104 straight 6,double roller chain lubricated.The only thing you need to do is if the engine starts leaking oil which the m104 is prone to do at 100k is ignore it and add oil or repair it at which time the head comes off and you check chain stretch.
Keep fresh conventional oil in it and maintain it properly.Learn to diy
mercedesshop.com or benzworld.org w210 section and enjoy it.
ohlord
Old Sep 4, 2008 | 07:56 PM
cliff's Avatar
the double roller-chain is outstanding....virtually indestructable
Old Sep 5, 2008 | 11:13 AM
topbuzz's Avatar
Thanks for your help Ohlord and Chris once again, for your expert advice.
Old Sep 9, 2008 | 08:13 PM
Scuddog's Avatar
My mechanic said the exact same thing as Cliff...
Old Feb 26, 2010 | 12:40 PM
ezdriver's Avatar
Default 99 E320 timing belt
I have a '99 E320 just turned 100k miles.
I just replaced the plugs and wires myself. It was a satisfying experience and I save a lot of money.
Can someone tell me if this car has a timing chain or a timing belt and what is the recommend interval for replacement?
Old Feb 27, 2010 | 10:05 AM
MB-TECH-38's Avatar
Default chain or belt
ezdriver
you have chain all BENZ have chains. chains never break its the plastic chain guides that go bad.
Jerry
Old Feb 27, 2010 | 11:08 AM
mbz connexion's Avatar
Slight rattling upon start up, chain tensioner??
How hard is it to change out?
Junger
Mar 20, 2013 05:38 PM
alanskip
Mar 19, 2013 05:41 PM
rogerc
Aug 30, 2011 04:40 PM
SSS
May 17, 2009 11:59 AM
Slkboi2000
Sep 5, 2006 07:01 AM
