no oil pressure
Old Aug 31, 2008 | 11:53 AM
350sd's Avatar
Default no oil pressure
I just did an engine swap. I transferred everything off of a 3.5L and put it on a 3.0L. Everything fit perfect, it started right up and purrs like a kitten. But I have no oil pressure. Because I completely drained EVERYTHING when I removed the engine do I need to prime the oil similar to fuel? Any thoughts?
Old Aug 31, 2008 | 10:04 PM
350sd's Avatar
Default RE: no oil pressure
I will recheck the wires and track down the oil sender. Like I said it was purring. Obviously I didn't run it long. Maybe a minute when I realized there was no oil pressure and it was telling the truth with the clacking valves. I immediately shut it down. It literally was not pumping any oil.
Old Sep 3, 2008 | 01:27 PM
350sd's Avatar
I ask the question again. Has anyone heard of having to prime the oil pump? If so how do I got about doing this?
I put in the required amount of oil via the filler cap. But since the entire oil cooler and lines were drained I have now put another 3.785L via the oil filter container. I am still not getting any oil circulating.
Old Sep 3, 2008 | 04:56 PM
cycleboy's Avatar
Priming an oil pump is essentially a standard procedure when rebuilding any engine. If the engine is drained, it's also a good way to make sure there aren't any air bubbles that would cause the pump to not work properly.
Old Sep 3, 2008 | 06:44 PM
350sd's Avatar
Okay, any info on info on how to prime it?
It's a '87 6cyl. 3.0L in a '92' 300SD 140 body style. Reminds of that Johnny Cash song.
Old Sep 3, 2008 | 08:16 PM
cycleboy's Avatar
Sorry, but I don't. On small block Chryslers there is a long rod that goes down to the pump that you turn with a power drill. I've never rebuilt a Benz engine so I don't have the foggiest.
Old Sep 3, 2008 | 10:47 PM
350sd's Avatar
Okay, thanks cycleboy. I guess I'll repost it "How do you prime an oil pump on a diesel?"
Old Jun 30, 2009 | 03:37 AM
raffo's Avatar
Default Transplant
350sd, how is the '87 engine holding up?
BarryO
Jan 30, 2012 08:34 PM
T Lindau
Dec 30, 2003 05:53 PM
zeaq
Dec 29, 2003 03:06 PM
benzuk
Dec 6, 2003 01:01 AM
chazola
Nov 12, 2003 01:04 AM
