BAS/ESP Light On
Old May 26, 2008 | 06:48 PM
aharley1's Avatar
Default BAS/ESP Light On
Cruising about 90 and all of the sudden,it felt like I went off the road. BAS/ESP light came on. Stopped & everything looked OK. When I started out, it felt like the RH rear brake was tapped ...twice. Made it home. Next day, everything worked fine ? ? ? What was that all about?:
Old May 26, 2008 | 08:29 PM
Default RE: BAS/ESP Light On
it must be a malfunction.
esp can apply the brake to a certain wheel without the driver's intervention.
Old May 28, 2008 | 06:36 AM
bazzle's Avatar
Also a diff in tyre diameter front to rear can give similar fault. Check for wear and/or tyre pressure problem.
error gets greater at speed.
Another thing can be an intermittant tone ring sensor or dirt in tone ring.
Bazzle
thealicat28
Sep 24, 2008 04:39 PM
rmt6668
Apr 28, 2006 05:53 AM
the prince
Apr 16, 2005 12:40 PM
