fault code, OM906LA engine
Old Nov 14, 2004 | 11:54 PM
boschtrans's Avatar
Default fault code, OM906LA engine
For Benz OM906LA electronic controlled diesel engine, the diagnosis connector are 14 pins, and only 5 pins are useful.
My question is how to trigger the fault code manually, for example, to connect some pins, then the system can flash code on dashboard.
I am in china, in many areas, there aren't Benz service stations, and not so many customers/service stations can afford Star or Mini-diag.
Thank you very much in advance.
Old Nov 15, 2004 | 12:58 AM
Default RE: fault code, OM906LA engine
give me the chassis number.
you are talking of transporter or truck...right?
i am in wenzhou and got everything you need, HHT or Star Diagnosis.
i was in Daimler-Chrysler beijing for quite sometime doing ACTROS and ATEGO, i can help you.
Old Nov 15, 2004 | 01:33 AM
ok, maybe you are talking of industrial engine also and chassis number is not possible.
i still got all the informations.
just tell me the 6 digits engine number.
906.900 - to - 906.989
Old May 7, 2008 | 01:33 PM
shary's Avatar
I have a stardiagnosis but I don"t have accece to use fdoc system how i can relearn the key transponder Thanks
Old May 14, 2008 | 04:40 PM
shary's Avatar
HI
I want ask pleas for ACTROS transponder key how to relearn without FDOK accese
Old Mar 1, 2009 | 09:08 AM
jon boy's Avatar
you carnt mate you need key gen no from yu lap top to put to f dok then codes show on f dok merc only jon boy if ya find a way let me know i am merc mech
Old Sep 14, 2009 | 04:51 PM
AVM2009's Avatar
Hi
I want to know where i can find the description and solution of codes that there aren't in the manual.
Saludos form Mexico!
Old Mar 3, 2010 | 02:33 PM
pippall's Avatar
I want to know why my Atego 815 is showing code on the display panel.And when you turn the key to the start position the starter keeps running with key turned off.Engine does not start.Engine number OM9044A.Chassiss number is WDB9700272K454163.
Old Jun 8, 2010 | 11:22 AM
abeid's Avatar
Default Fdoc access
i have a stardiagnosis but i don"t have accece to use fdoc system how i can relearn the key transponder thanks
hello everybody
am also having the same problem, having the stardiag and i cant
relearn the key transponder of my axor truck which lost its key.
Kindly help.
Thx in adv.
Old Jun 8, 2010 | 01:13 PM
abeid's Avatar
is there a way to emergency start an axor truck in case i lost key even if its temporary.
kindly help.
