AC Off Red Light Remains
Old Mar 28, 2008 | 07:22 AM
LGSRAY4's Avatar
Default AC Off Red Light Remains
I own an S430 2004. The air conditioner is notworking and the "AC OFF" light remains on. The AC can not be switched on. Help, it beginning to get hot!!!
Old Mar 30, 2008 | 12:32 AM
saleen1276's Avatar
Default RE: AC Off Red Light Remains
there is a leak in the sysem or a faulty sensor....most likely a small leak...it has to be reset by the dealer...disconnecting the battery will not reset it...have the system checked out and dye insertied to locate leak and recharge sytem...should take approx 2.2 to
2.7 lbs r134a
Old Apr 6, 2008 | 03:09 PM
Peter Guenther's Avatar
The red light indicates the compressor is not running. You either have a bad pressure sensor, or a leak. Try the diagnostics
http://www.continentalimports.com/ser_ic40142.html
LINDALUCY16
Aug 19, 2009 11:17 AM
LINDALUCY16
Aug 19, 2009 11:04 AM
Gene Moses
Feb 24, 2008 02:16 PM
Gene Moses
Feb 22, 2008 05:21 PM
jaredtroth
Jul 17, 2007 10:42 AM
