TURBO SQUEAL!!
Old Mar 19, 2008 | 12:57 PM
danpayton's Avatar
Default TURBO SQUEAL!!
So my turbo has started squealing like MAD...
I was thinking I could just stick another used on in there.. but I was wondering, is there another replacement I could use, that spools a bit faster?
I dont really need more boost on the top end, but getting it up to PSI quickly would be nice...
or any other thoughts on non-stock replacement turbos?
and im not opposed to installing an EGR gauge if needed ;^)
BTW..
EGR blocked
No Cats
Straight pipe exhaust (no muffler)
ALDA removed
325k miles..
thanks in advvance!
-Dan
82 300 SD5 cyl Turbo
Old Mar 20, 2008 | 11:50 AM
danpayton's Avatar
Default RE: TURBO SQUEAL!!
is there a way to tell the 2 turbos apart easily in the junkyard?
thanks!
Old Apr 15, 2008 | 04:06 PM
danpayton's Avatar
So another question.....I'm pretty sure Ialready know the answer.. but what happens if you run this motor without the turbo? assuming a person has installed the correct bypass piping?
thanks
-Dan
Old Apr 16, 2008 | 11:28 AM
danpayton's Avatar
Running like that wont damage the engine with lower input pressures or anything?
Well I guessI know of people (grandparents) that drives these carsin such a way that they NEVER spool the turbo...
thanks for the info!
Old Oct 16, 2009 | 03:15 PM
chrisarnt's Avatar
What does removing the ALDA do?
Old Oct 26, 2009 | 10:40 AM
Oldwolf's Avatar
Can't you rebuild your turbo? I don't know the answer, I'm just asking.
Ellen Ward
Dec 13, 2006 06:02 PM
svcandleinfo
Apr 24, 2006 02:36 AM
champion
Apr 24, 2006 02:28 AM
Xacting
Dec 24, 2005 10:37 PM
AMGBenz
Jan 23, 2005 05:02 PM
