EPC problem
Old Feb 27, 2008 | 07:03 AM
E220's Avatar
Default EPC problem
Hi everyone.I have a E220 yr 00.When i speed up and when i press on the small switch behind the accelerator,it shows me Epc problem.Can anyone help me as the car is slow and the only way to get some power is the small switch.PLZ
Old Feb 27, 2008 | 08:41 AM
E Cls Owner's Avatar
Default RE: EPC problem
Your car has gone into "limp homemode"... You will not get much in the way of acceleration until the problem triggering this condition is corrected. If you have an OBD-II reader, pull the codes and post them here so that some for the forum members can assist you in sorting this out.
If you don't have a reader, then take the car to an Auto Zone store and they will pull the codes for you. Just get the codes, and the clerk's interpretation of them...
JR
Old Feb 27, 2008 | 11:10 AM
ohlord's Avatar
Banned
Where are you located?
pULL THE codes per above, although diesels are prone to throwing the limp mode and fine on start only to trip the mode again.Clean the EGR valve tube it is most likely blocked ,and check all hoses to the egr for wear cracks etc. symptoms also can indicate a dirty mass air sensor,crc brand maf cleaner will clean it.
More diesel members are on mercedesshop.com diesel forum.
Old Jun 28, 2011 | 05:10 AM
GERTI85's Avatar
Default HI
Hi i have a mercedes e220 diesel 1996 and when show me epc light the gears of my car max go to 3500 and when i tun off then i tun on the engine works normally then do the same thing againpls help me where is the problem
Old Feb 16, 2012 | 05:54 AM
Luv Jaiswal's Avatar
I have a Mercedes E220 CDI Automatic 2002. The pick up is not as powerful as it used to be. My friend told me about the small button behind the accelerator which gives more power. I did that on which my screen read EPC problem. What is this problem? Please help.
jncruz
Jan 17, 2011 05:10 PM
Madvik
Dec 18, 2008 03:55 PM
boro1
Jul 8, 2007 02:19 PM
hammer23
Mar 14, 2004 11:42 AM
Jasper
Feb 9, 2004 02:23 PM
