sudden limp home mode and asr light on
Old Jan 29, 2008 | 07:03 PM
s10zer's Avatar
Default sudden limp home mode and asr light on
WHAT COULD CAUSE SUDDEN LIMP HOME MODE AND ASR LIGHT ON IN MY 1993 600SL? APPRECIATE ANY HELP WITH THIS MATTER .
Old Feb 4, 2008 | 04:05 PM
bobterry99's Avatar
Default RE: sudden limp home mode and asr light on
If socket #6 is wired to your diagnostic connector, then you can easily read diagnostic codes for ABS/ASR as explained here: http://www.benzworld.org/forums/r129...-pre-94-a.html?. A '93-'95 V-12 or V-8 car is prone to deterioration of the engine wiring insulation, and this could be the cause of your problem. Another would be that one or both of your throttle actuators are faulty.
Old Feb 18, 2008 | 02:36 PM
Mooseman101020's Avatar
See the post that I just put up. Good luck. There are several causes for this problem. You can spend a lot of time and $$$$ going through the list. Even the dealers don't always get it right the first or second time. It cost me $1400 to replace the deteriorating engine harness but it solved the problem. Thing is; thatbad harnessis going to fall apart and cause some issues sooner or later (ASR light and LHM being just one of the issues).
andrewandlorraine
Jun 21, 2025 01:08 PM
s10zer
Jan 28, 2008 09:26 PM
greekpilot767
Mar 17, 2007 02:34 PM
d4vey
Dec 21, 2005 07:42 AM
addys
Jun 23, 2005 12:09 AM
