ASR Problem
Old Sep 29, 2003 | 09:03 AM
riallayla's Avatar
Default ASR Problem
I have 1992 s500. Sometimes ASR light turns on and the car stop accelerating which means I have to stop eventually and restart again can any one please tell me what the problem is and how to fix it? I took it to car repair and they changed the sensers but the problem came back again
Old Oct 17, 2003 | 02:14 PM
BuyMBparts.com's Avatar
Default ASR Problem
probably the wireing harness, we sell them all the time
Old Nov 21, 2003 | 08:57 AM
jacob's Avatar
Default ASR Problem
Hi Riallyla</P>
Did you solve the problem with the ASR , since I have the same problem with my 560 sec, Please let me know if you know what is the problem.</P>
Thanks</P>
Jacob</P>
Old Dec 14, 2003 | 11:16 PM
Natedawg8847's Avatar
Default ASR Problem
i had a 94 s600 a couple of days ago
i put a wiring harness in it.
the wiring harness cost $1500
and the labor was around 20 hours.
the car has not been back since.
i cannot say this will fix your car.
but more than likely you're car needs a wiring harness regardless.
Old Dec 22, 2003 | 02:05 PM
enterjohn's Avatar
Default ASR Problem
Did anyone ever fix this ASR problem? I have been having it for about 6 months on and off. Haven't taken it to a dealer yet as it always self corrects. Sometimes for a month. Lately it is more frequent.</P>
Old Dec 27, 2003 | 11:23 AM
Peter Guenther's Avatar
Default ASR Problem
This must be a time issue, my 92 500 SEL (70K miles) started this stuff a few months ago. It seems that it is happening at a increasing rate, a restart seems to clear it all the time but required two tries the last time.</P>
I think the brake lamp switch has been identified, cheap fix! Corroded connections on wheel sensors another. The idea of replacing the throttle control, or the harness, is not something I want to jump on quickly. According to my information the failure should set codes that MB can retrive via the body computer. I wll go that route, my dealer is usually pretty good.</P>
If it fails with regularity, it may be time to trade it out</P>
Old Feb 22, 2005 | 05:21 PM
PETER012481's Avatar
Default RE: ASR Problem
HOW DID YOU MAKE OUT WITH YOU ASR PROBLEM . I HAD THE SAME PROBLEM BROUGHT IT TO THE DEALERSHIP AND THEY ENDED UP REPLACING THE LATERAL ACCELERATION SENSOR AND WHEEL SENSORS WORKED OUT FINE , I HAVE A 92 500 SEL 222,000 MILES AND STILL KICKING
Old Oct 8, 2005 | 06:06 PM
cool's Avatar
GUYS, THE CULPRIT IS THE WIRING HARNESS AND THE ELECTRONIC THROTTLE ACTUATOR HARNESS AND SUBSIUENTLY THE EGAS CONTROL MODULE WILL BE DESTROYED, NOT THE BRAKE SWITCH.
Old Dec 7, 2005 | 10:21 AM
ej5017's Avatar
I have a 1991 500SL and ASR problems. Mine won't go off. The dealer quoter $2500.00 for the module. Any way to bypass this without upsetting the computer or anyone direct me to a cheaper part, new or used?[:@]
Old Aug 3, 2006 | 08:28 PM
ISpyinLA's Avatar
I had the ASR come on in my 1991 500 SL and after repeated trips to the shop, they wanted to replace the wiring harness. Lots of $$. Began to research matter and my problem turned out to be located inside the control head of the electronic acelerator harness. Although sealed, water somehow got in and caused damage. Replaced just this harness and all is well for past 10 thousand miles.
This harness can come off but must be properly placed back on.
Paddy
Sep 17, 2008 07:22 PM
jordanman
Dec 30, 2004 08:52 AM
goodluck
Dec 3, 2004 03:39 AM
jacob
Nov 21, 2003 09:01 AM
byttcool99
Sep 13, 2003 05:34 AM
