what is up with my car...gear won't go to Drive...
Old Sep 14, 2007 | 01:51 PM
todesto's Avatar
Default what is up with my car...gear won't go to Drive...
It has to do with my brake, I think....
When I start the car and step on the brake to get gear from P to D, BAS/ESP light come on and I can't get gear to shift from P to anywhere.... I have to press release button to shift the gear [:@]
Is this common problem? Is this something that can be fixed after I change to new brake pad? (I need new brake pad anyway)
Thanks in advance.
GP
Old Sep 14, 2007 | 04:59 PM
NAZ's Avatar
NAZ
Default RE: what is up with my car...gear won't go to Drive...
sounds more like faulty brake light switch you ll be supriesd wat a brake ligth switch does its the main part of the ESP BAS AND THE ABS need to diagnose before replacin switch is not inexpensive its about£10.00
Old Sep 14, 2007 | 09:45 PM
todesto's Avatar
Thanks for the quick reply. Is that something I can switch myself or dealer only thing?
Old Apr 3, 2009 | 09:31 AM
fiscust's Avatar
Cool shifting from park
I have a 2001 ml 350 and i could not change from Park to anywhere. There is an override on the console you can put a little pin or file in and it holds in the override and allows you to switch gears. It worked for me. Still working after about a year.
Old Apr 7, 2009 | 09:12 AM
Google brake pedal switch replacement and you will find DIY easy step by step instructions.
Goldengirl1
Nov 8, 2012 07:28 PM
Pholmqvis
Mar 5, 2012 02:15 PM
andeveron
Jul 1, 2006 04:10 AM
AMGDragon
Jun 29, 2005 03:40 AM
