transmission problem
Old Aug 13, 2004 | 07:07 PM
89190e's Avatar
Default transmission problem
hello, i have an 89190e 2.6. car will not go forward, only goes in reverse. when transmission is in a forward gear, acts as if in neutral. just looking for ideas of how to fix besides replacing whole tranny. fluid is very clean. thanks for any ideas and info.
Old Aug 14, 2004 | 02:10 AM
Default RE: transmission problem
the teflon ring on the piston of brake band 2 is damaged. just replace it.
you will see it from the side of the transmission...right in front of the governor. it's the round cover. there's two strong springs inside, so remove it with caution. the lock ring is on the side.
do not replace the transmission not unless the casing is broken.
Old Aug 15, 2004 | 07:15 PM
89190e's Avatar
i really appreciate the fast response. i will try what you recommended on monday.
thanks
surf077
Jun 21, 2005 12:52 AM
surf077
Jun 21, 2005 12:49 AM
mexicocrow
Feb 2, 2005 03:17 PM
billaq
Nov 14, 2004 09:24 AM
KELBEL
Jun 25, 2004 10:10 PM
