1995 S320v Need advice, thanks
Old Mar 17, 2004 | 09:56 PM
shayne crowe's Avatar
Default 1995 S320v Need advice, thanks
<FONT size=2>I have a 1995 S320v w/ 60K miles. Car runs excellent with no problems howerver, After I have been at interstate speeds (80mph) and then slow down to normal driving speeds, the car starts missing. It feels like it is only firing on 4 cylinders, running rough to say the least. However, as soon as I turn it off and restart, the car runs fine. This only happens infrequently and when it does no indicator warning lights appear. Any suggestions? I'm thinking computer problems, spark plug wiring, spark plugs, etc. what should be my first step? Thanks for your help it is appreciated. </FONT></P>
<FONT size=2>I just think that it is odd that I can go a week without a problem and then it will happen three times in one day and always after I slow down and start to accelerate again. Confused.</P>
Shayne</FONT></P>
Old Apr 13, 2004 | 09:46 AM
Rossie's Avatar
Default RE: 1995 S320v Need advice, thanks
Not so sure about a V6 in an S class...
Too weak...
I had this sort of problem with my S500 Coupe and 300E before.
The 300E's problem came from the starter, whilst the S500 Coupe came from the electronics.
Ask your mechanic to check those parts first.
I hope that helps a little.
Old Apr 16, 2004 | 01:49 PM
your car have ASR?
Old Apr 21, 2004 | 12:02 AM
SANDDOG's Avatar
Hi Shayne, Your engine is an inline 6, not a V6 excellent motor. One of the best ever built. Anyhow I believe its your plug wires, Mercedes had a recall on the wiring harness some time ago, on most 1995 cars Like 7 years. The harness is to short and starts to break down from heat & oil. Spark plug area seems to be the first to go, if there is a harness problem ? Be very careful removing the plug boot from each spark plug as they include a coil attached on the top of each plug. Always disconnect your battier. One or more of your plug wires or maybe a coil is breaking down when real hot. The coils are about 200.00 each. Buy on line not the dearler. Good luck thats my best guess
nbrock_85
Jan 9, 2012 08:20 PM
gearbox93
Mar 21, 2009 05:40 AM
rwaters711
Aug 25, 2008 02:34 AM
S500sport
Apr 10, 2008 07:53 PM
shayne crowe
Mar 17, 2004 10:04 PM
