problem whit 400cdi
Old Feb 3, 2006 | 12:53 PM
  #21
jalmari17's Avatar
Default RE: problem whit 400cdi
so that webasto thing... is forgotten... still -25c*here would be nice to start webasto before starting car....
Old Sep 29, 2009 | 10:32 AM
  #22
velasala's Avatar
Default 400 cdi egr valve
Originally Posted by sleepwalker
was that E-Class, S-Class or M-Class?
i assume S-Class and here's the answer anyway:
[IMG]local://upfiles/1/7E87B0ADC06A4DFC89EAB6BCB2683957.jpg[/IMG]
hi, I´ve the same problem with the egr valveon my S400 cdi, but I cannot open this link, can I see it somewhere else?
Old Feb 28, 2010 | 01:17 PM
  #23
chetan bhatia's Avatar
Default 400 CDI W220 2002 turbocharged Mercedes Diesel troubles
I just joined the forum, and have read a bit here, which has been very useful. Here is my problem:
My car smokes a lot, and has terrible black smoke coming out. The Star scan showed as follows:
Cylinder 2 and 3 signal faulty (P2017-008 & P2017-032)
This is probably a wiring problem or earth issue and I am sure the mechanics can fix it.
P2024-008 Check component Y27/9 (Left EGR positioner) Positioner signal fault (message through ground key)
P2024-008
Check component Y27/10 (Right EGR positioner) Positioner signal fault (message through ground key)
My problem is that my car is in Africa, and they cant find where the EGR is or what it looks like!!! I have cleaned the intake manifold on top, and the turbocharger. How can I get to the EGR to clean up the carbon, and is it also an electrical problem?
Thank you guys! Please help!
Old Dec 11, 2010 | 09:50 AM
  #24
atiffia's Avatar
i have mercedes C200 diesel automatic. When i press accelerator, there is no power, it moves very slow, i did a diagnostic and this came up ( Component stored Y27/9(Left EGR postioner). Positioner signals fault
Any suggestion??? thanks
BALTICSTONE
May 23, 2008 04:28 PM
e320drivemecrazy
Mar 11, 2008 06:02 PM
rameets
Jun 20, 2007 02:43 AM
legenesepimp
Nov 4, 2005 01:36 PM
