secondary air injection malfunction P0410
Old Oct 29, 2009 | 10:30 AM
timmified100's Avatar
has to be an electrical issue if you already checked air pump manually & it turns on. I would still change relay anyway & try that first
Old Nov 8, 2009 | 08:37 PM
dls's Avatar
dls
Where is that pump located?
Old Nov 9, 2009 | 10:30 AM
on c320 it's located on the front top of engine you can see it after you pull off motor cover
Old Nov 11, 2009 | 01:09 AM
dls's Avatar
dls
Thanks for your response.
I have a S430 and now I know where is that air pump located.
After I pull of the motor cover, I found this air pump disconected. I connected again but realize that it stayed on constantly. I decide to leave it disconected since I know this should run for aprox. 20 sec.
Any ideas?
Thanks.
Old Nov 11, 2009 | 10:09 AM
I would try air pump relay I believe located in fuse box under hood on driver's side next to master cylinder
thomasmaio
Mar 13, 2015 01:49 AM
rzm
Nov 20, 2013 01:33 PM
timmified100
Jun 28, 2011 06:21 PM
gruf
Sep 28, 2010 05:17 AM
Reshad
Dec 29, 2006 07:45 AM
