I would go to this site where he has a pictorial on how to check your Glow Plugs (you will need a Volt/Ohm Meter; Harbor Freight sells them for $3).
When the site opens up you will have to scroll down the page as at first it looks like there is nothing there.
In the 2nd picture of the Glow Plug Relay; on the left you will see a metal strip. That metal strip is the Glow Plug Relay Fuse. If it is not burned take a really close look to see if it is cracked as that can be hard to see.
http://www.dieselgiant.com/glowplugrepair.htm
After doing the above let know what you found.
These sites might also be of interest: Repair Links
http://www.peachparts.com/shopforum/...splay.php?f=82
http://www.peachparts.com/Wikka/DoItYourSelf
